Group: DynoMotion Message: 8168 From: hsontag1 Date: 8/26/2013
Subject: Re: Bit status on startup for KFLOP
Are the values of the digital outputs from the KFLOP also indeterminate at startup? I am using (2) SnapAmps, not Kanalog, along with a few digital outputs from KFLOP to control things like air and mist.
I need to figure out whether I need to keep +12V power off to peripheral devices until after startup.
Hugh Sontag
> Hi easydigisoft,
> The SWE relay driver output is guaranteed to remain off until after all the Kanalog Outputs are initialized off.  You will need to use that, or some other means of keeping everything disabled until after the Kanalog Outputs are initialized.
> From: easydigisoft <easydigisoft@...>
> Sent: Monday, August 19, 2013 11:20 AM
> Subject: [DynoMotion] Bit status on startup
> Ok so I am almost finished with connecting my cnc but when I power up the KFLOP and Kanalog it seems like for few seconds every pin goes high. At that moment everything is turned on, my chip, hidraulics pump, emulsion pump spindle, EVERYTHING. So it takes a lot of power and the fuse shuts it off. Is there a way to set KFLOP not to turn on all pins to high on startup? thanks.
Group: DynoMotion Message: 8169 From: Tom Kerekes Date: 8/26/2013
Hi Hugh,
The KFLOP IO pins power up as inputs.  Initially with weak pull downs and then float (until configured and set).  Some (first 8 on JP6) have stronger 150ohm pull downs and will not float.   The pins on JP7 will float but there will be a burst of activity for ~90us to attempt to autodetect a Kanalog.
Group: DynoMotion Message: 8170 From: Hugh Sontag Date: 8/26/2013
OK, thanks for the info. Because the SnapAmps will be used for differential encoder inputs, I'll probably pull down some or all of I/O 0 - 7 and use those as outputs to switch things like air or mist.
Hugh
On Mon, Aug 26, 2013 at 5:30 PM, Tom Kerekes <tk@...> wrote:
Hi Hugh,
